I don’t understand, why would it be linked to a DNS problem?
I did a tcpdump and there was not any error, only some 6sec blank between the login and the password request, an other blank between the password and message, and a last one before the directory listing.
When you are connecting to the VS, are you using the public IP or the domain ? If domain, check to see the DNS resolution time and try and use the public IP instead of the domain to check if there is any difference in performance.
Sorry I forgot that people indeed use the DNS name for this public IP, but I realized all my tests with the public IP directly and had the same issue.
I made some intensive tests and the issue seems to be related to the server behind because everyone always have these delays when connecting to this specific FTP service.
Our windows team is now investigating, therefore this topic can be forgotten and offered to Chtulhu
Tough to answer without seeing the packet capture. Are you seeing still seeing the same issue directly to the server and via F5 ? Try disabling Nagle’s algorithm on F5 (or server) and see if it makes any difference.
Take a tcpdump to see where the issue is, there is no point guessing. Then you can define the problem better and target your investigation. I mentioned DNS before because the server often uses DNS to resolve the name of the incoming IP address. If it can’t do that eg SNAT then it can cause a delay on the server
it would be useful to check both sides, is there anything coming from the FTP server which the BIG-IP doesn’t pass through or does the BIG-IP wait on sending something.
this is way easier to trouble shoot for f5 support, if you haven’t already open a support ticket.
