Slow data transfer between the Internal VLAN and Appnet VLAN.
Izar/Polaris Network Layout: Big/IP LTM 7000 (Model D110) running F5 OS 12.1.2 - Engineering Hotfix HF1
Spine 1 and Spine 2 devices are Cisco Nexus 9000 C9396PX running NXOS 7.0(3)12(2a).
Software BIOS: version 07.34
NXOS: version 7.0(3)I2(2a)
BIOS compile time: 08/11/2015
NXOS image file is: bootflash:///nxos.7.0.3.I2.2a.bin
NXOS compile time: 12/14/2015 4:00:00 [12/14/2015 07:23:53]
Hardware cisco Nexus9000 C9396PX Chassis
Intel(R) Core™ i3- CPU @ 2.50GHz with 16401956 kB of memory.
Processor Board ID SAL19017B8S
Spine 1 and Spine 2 Configurations:
Spine1:
vlan 10
name 10Net-Data
vlan 700
name ASM-BigIP
vlan 710
name BigIP-ExchNet
interface port-channel11
description “Spine to Izar Internal”
switchport mode trunk
spanning-tree port type edge trunk
vpc 11
interface port-channel12
description “Spine to Polaris Internal”
vpc 12
interface port-channel700
description “Spine to Izar Appnet”
vpc 700
interface port-channel701
description “Spine to Polaris Appnet”
vpc 701
interface port-channel710
description “Spine to Izar Exchnet”
vpc 710
interface port-channel711
description “Spine to Polaris Exchnet”
vpc 711
interface Ethernet1/17
description “Izar Internal”
no cdp enable
channel-group 11 mode active
interface Ethernet1/18
description “Polaris Internal”
no cdp enable
channel-group 12 mode active
interface Ethernet1/19
description “Izar Appnet”
no cdp enable
channel-group 700 mode active
interface Ethernet1/20
description “Polaris Appnet”
no cdp enable
channel-group 701 mode active
interface Ethernet1/21
description “Izar Exchnet”
no cdp enable
channel-group 710 mode active
interface Ethernet1/22
description “Polaris Exchnet”
no cdp enable
channel-group 711 mode active
Spine2:
vlan 10
name 10Net-Data
vlan 700
name ASM-BigIP
vlan 710
name BigIP-ExchNet
vpc 11
vpc 12
vpc 700
vpc 701
vpc 710
vpc 711
no cdp enable
no cdp enable
no cdp enable
no cdp enable
no cdp enable
no cdp enable
TESTING RESULTS:
Izar is Primary. Polaris is Secondary.
Test results using Iperf3 while testing bandwidth through the Big/IP units:
result VLAN
Client VLAN APPnet
Server VLAN APPnet
Results: 8.3 Gb/s and 7.7 Gb/s
Client VLAN Internal
Server VLAN Appnet
Results: 48 Mb/s and 27.1 Mb/sand 46 Mb/s
Server VLAN Internal
Results: 2.04 Gb/s and 1.77 Gb/s
Client VLAN Exchnet
Server VLAN Exchnet
Results: 9.4 Gb/s
Client VLAN Exchnet
Server VLAN Appnet
Results: 836 Mb/s and 903 Mb/s
A diagram and some hints on how you have configured your BigIP’s would be useful.
