Sizing for HW and SW based
I am looking for a data for dimensioning for r5800 / 6000 etc where I am deploying DNS+PEM+AFM+URL Filtering + some iRules on ONE rSeries
The same witch I am looking for is for VE deployment
Where I can find data about such figures
I can only find for DNS QPS, but for the rest of the modules can’t
Are there any exact numbers?
How can I combine and calculate this module and see if feet into rSeries and VE HP??
@mroslon
Hello  I  found these articles that may  help  answer your questions for system requirements for setting up  your Tenants or VEs
F5OS
Tenant Management (f5.com)
Big-IP
Hardware requirements to host BIG-IP VE on private cloud platforms (f5.com)
@mroslon - if you found your answer here (or have since resolved your questions) it would be great if you selected Mark As Solution on either this reply or an outline of how you solved the issue.
Mark As Solution helps the community-at-large for months and years to come.
Thanks.
