I wrote the iRule below and I’ll appreciate if anyone can tell me if have another and/or better way to do that.
I have an case which the communication needs to be persisted with source address regardless of the member becomes offline. This is due to the client access can’t start a new session on another server in certain period.
By default persistence, the Big-IP will always send connections to the available server, so I need to discard this option. I also tried to setup the monitoring up time, but it was not very effective.
As the persistence record is cleared when load balance fails, I use the table command.
Does anyone know of a better way to do this?
when RULE_INIT {
set ::debug_enabled 1
set ::persist_table "source_addr_sticky_uie"
set ::persist_timeout 1800
when CLIENT_ACCEPTED priority 300 {
persist virtual server
set persist_key "[IP::local_addr]:[TCP::local_port]:[IP::remote_addr]"
set persist_record [table lookup -subtable $::persist_table -notouch $persist_key]
if { $::debug_enabled } { log local0. "===> persist_key: $persist_key / persist_record: $persist_record" }
if { $persist_record ne "" } {
if { [lsearch [active_members -list [LB::server pool]] $persist_record] ne -1 } {
pool [LB::server pool] member [lindex $persist_record 0] [lindex $persist_record 1]
table lookup -subtable $::persist_table $persist_key
if { $::debug_enabled } { log local0. "===> Selecting pool member $persist_record / persist_key: $persist_key" }
if { $::debug_enabled } { log local0. "===> Updated timeout record table $persist_key" }
reject
if { $::debug_enabled } { log local0. "===> Failed to select pool member $persist_record / persist_key: $persist_key" }
log local0. "===> Dump table: $::persist_table"
foreach key [table keys -subtable $::persist_table -notouch] {
log local0. "===> ${::persist_table}, ${key}, [table timeout -subtable $::persist_table -remaining $key]"
unset -nocomplain persist_record
when LB_SELECTED priority 300 {
table add -subtable $::persist_table $persist_key [list [LB::server addr] [LB::server port]] $::persist_timeout
if { $::debug_enabled } { log local0. "=======> Member selected [LB::server addr]:[LB::server port] / persist_key $persist_key" }
when LB_FAILED priority 300 {
LB::detach
reject
if { [info exists persist_key] && [info exists persist_record] } {
log local0. "===> Fail to select member $persist_record / persist_key: $persist_key"
