SIP SBC Communication Fail
Hello @ALL.
I have a problem with a SIP Load Balance communication between F5 BIG-IP and SIP SBC.
My SIP Topology is:
Client > F5 > SBC > F5 > Capture Proxy.
The F5 BIG-IP is in on-arm into the topology. Then I need to use SNAT to the packet come back to F5 BIG-IP.
So far so good …
The comunication between F5 and Capture Proxy is ok, because I use a iRule to manipulation source address, replace the IP from BIG-IP SNAT to client IP:
when SIP_REQUEST {
set addr [IP::client_addr]
when SIP_RESPONSE {
Check for 302 responses
if {[SIP::response code] == 302}{
    log local0. "302 OK"
      if {[scan [SIP::header value "Contact"] {%[^@]@%[^:]} a b ] == 2}{
        SIP::header replace "Contact" "${a}@$addr>"
But the traffic between F5 and SBC I aways receive the “Status: 403 Forbidden-Source Endpoint Lookup Failed”
I think that this problem can be with the SIP Request-Line and another header, but I change all SNAT IP to client IP by iRule:
when LB_SELECTED {
set pool_member [LB::server addr]
    log local0. "[LB::server addr]"
when SIP_REQUEST {
log local0. "Current uri: [SIP::uri] "
SIP::uri [string map "[IP::local_addr] $addr" [SIP::uri] ]
log local0. "New uri: [SIP::uri]"
if {[scan [SIP::header value "To"] {%[^@]%s} a b ] == 2} {
    log local0. "Checking $a $b"
    SIP::header remove "To"
    SIP::header insert "To" "${a}@187.60.52.80>"
    log local0. "New Header TO [SIP::to]"
Can someone help me about that??
Kinds Regards.
