SIP proxy BYE messages handling
We have multiple SIP proxy behind F5 load balancer and we are using
Record-Route
to keep F5 in path but i have notice my
ACK
message was bouncing back and not going through in that case i add following iRule which fixed issue but now my BYE message is not getting handle correctly
when SIP_REQUEST_SEND {
    SIP::header remove "Route"
In BYE message i am seeing it has wrong R-URI and it has F5 SelfIP address in BYE instead of End-User
BYE sip:tester@F5-SelfIP:41623 SIP/2.0
I have notice my
Contact header
has that address. anyone having this issue?
We are using
Automap
for SNAT
Hi Satish,
Please share the SIP message flow to give exact solution.
In clients normally Request-URI for in-dialog request ACK/BYE will be framed from Contact header of 200 OK of SIP INVITE. If the Contact of 200 OK is altered in F5 then you should avoid manipulating Contact header.
Syed Nazir
Thanks Syed,
I found small config issue in SIP proxy server which fixed that issue. but i have one more question which is related to SIP also DevCentral - An F5 Technical Community
