I need to be able to create a SIP monitor that uses the REGISTER method rather than using the standard OPTIONS method that our current SIP monitor uses.
A packet capture of the current monitor looks like this.
I don’t think you’d want to use an iRule to do the health checking as the rule would only be triggered when a client request is received.
Maybe I’m missing something, but I think you could just use a TCP monitor with the request you posted above configured in the send string of the monitor. You can separate lines with \r\n.
Else, you could write an external monitor to make the exact request you want.
Askf5.com should have information on configuring custom and/or external monitors.
Thanks, I’ll try that. Is there a way to generate a random number for the branch portion of the request and insert it as that needs to increment each time?
I don’t know of any scripting functionality available in the default monitor send string. If you really need to generate an index, I think you’d need to write an external monitor.
