SIP Header manipulation
I’m new to SIP and I have a problem that I think can be solved with an iRule.
Within my SIP header I need the CONTACT information to reflect the VIP address and not the private address of my SIP server. Currently the packet looks lie this:
--cut--
Contact:
Contact Binding:
URI:
SIP contact address: sip:10.12.1.25
--cut--
I need it to look like this:
Contact: (hiding complete address)
Contact Binding:
URI:
SIP contact address: sip:66.43.x.x
I should clarify, that when I said “if the string you want to replace is within the data of the packet (as opposed to the header)” I meant the payload of the TCP or UDP packet the SIP is being sent in.
Aaron
I appreciate the response.
I’ve actually looked into a stream profile, but I don’t see a way to apply a stream profile to UDP traffic. Is that possible?
