I am currently using an ISAPI filter, basic authentication, and a cookie to achieve single sign on for a portfolio of web applications/servers. I’d like to be able to cut out the ISAPI filter for ease of maintenance and expanding support across non-IIS web servers.
Has anyone used an iRule to simulate a “forms” based type of authentication over multiple web servers? I am think the iRule could do something like this:
- Check for existence of login cookie
- No cookie - 302 to anonymous login page (SSL)
- User submits login (validate against LDAP) creates two cookies - “login cookie” and “auth cookie” (base64 encoded user/password)
- “login cookie” exists - check for “auth cookie”
- “auth cookie” is appended as WWW-Authenticate
-no “auth cookie”, send 401 to client
-on error - 401 to client
Does this seem like something an iRule could do? I am a complete beginner on iRules - any help would be great!!
Hi Michael,
That seems fairly reasonable to achieve in an iRule. I don’t think it would be a simple iRule to start with though. If you want LTM to authenticate the client requests against an LDAP database, you’d need to get the Advanced Client Authentication module. You can check with an F5 salesperson or partner to find out how much that would cost (How to get BIG-IP hardware and software | F5).
One small note: base64 encoding wouldn’t encrypt or secure the username/password. If you want to store the user/pass in a reversible form in a cookie, you’d probably want to encrypt, base64 encode and then URL encode the values.
http://devcentral.f5.com/wiki/default.aspx/iRules/AES\_\_encrypt.html
http://devcentral.f5.com/wiki/default.aspx/iRules/b64encode
http://devcentral.f5.com/wiki/default.aspx/iRules/uri\_\_encode
Aaron
I was planning on the anonymous logon page to verify against LDAP and set cookie[s] based on the response from the web server.
Is “AUTH_WANTCREDENTIAL” the correct event to “intercept” the 401 challenge to the browser?
I was thinking something like this…
when AUTH_WANTCREDENTIAL {
Logic to check for cookie set on “login” page
IF Cookie Not Found
HTTP::respond 302 Location ]
