Hello,
How to configure single sign on on F5 Ltm? please help. Thank you.
Hello,
On LTM it’s depend what you want to do. You can do it using Irule (Not natively like apm). So can you explain your need and we will help you to achieve it if it’s possible.
One question did you have APM? if not how you authenticate user for process SSO?
regards
Do you currently use F5 LTM (not APM) to authenticate user sessions for some application?
If you have APM as an option I would recommend looking into provisioning and using APM as it would be a lot easier than trying to do anything in LTM.
If you do need something in LTM it would be an iRule, or even a set of iRules, but would need to know what you are trying to do in more detail before we could help.
