Simplest ping is not working between cisco switch and F5
I have created a vlan put 1 interface in that vlan as untagged as interface on the cisco switch side is access. created self ip of the vlan. Now i try to ping the SVI on cisco switch but ping stops from my own self ip. Same ping is unsuccessful from the cisco switch side. I have already installed 2 F5 and i am out of ideas that why ping is not working. when i take the cable out of F5 and put in laptop and try ping from laptop it works but not from F5. Please any idea. version is 11.2 in my previous F5 version was 11.4.
please help help
Self IP and laptop/switch IP on the same network?
Can you ping the self ip itself on the F5?
What if you take out the cable from the switch side and plug into the laptop - can you ping the self ip and vice versa?
yes self ip and switch ip are on the same network. Yes i can ping the self ip from inside the f5. I will answer your 3 question after checking. thanks sir for your reply.
ping from laptop to F5 and from F5 to laptop is also not working.
Check to see if the interface is up: “tmsh show net interfaces” if not, can you try a different interface on the F5?
interface is up. when i try pinging even statistics of interface show increased traffic but ping is failing.
I would check the masks, duplex and basic network settings. If that is all fine, recommend taking a tcpdump of the traffic and deducing from there.
We used a different interface + the interface configure for internal and external VLAN as well by giving self IPs to the laptop but from the F5 CLI prompt no reply of the ping response to the self IP.
mask is correct, duplex is full. I have taken tcpdump it shows ping requests coming towards self ip but i am not seeing any response give back.
If i take out cable and put in laptop i can ping cisco switch it means cisco switch is fine If i put switch end in laptop and try to ping F5 self ip it fails and viseversa. Which means something not right in F5 what configuration it takes on F5 end? make a vlan, put one interface in it and select it as untagged. give a self ip and ping it from directly connected laptop. but its failing. ahhh please help.
Connecting the internal & external VLAN cable coming from the core cisco switch to the laptop and configuring the laptop with internal self ip/gateway and external self ip/gateway the ping works and all the servers are responding to the ping indicating no issue towards uplink..
UWhile connecting it to the core switch using Layer-2 network with access ports on both sides, unable to move out of F5 LTM ahead of internal SELF IP which replying “Destination Host Un-reachable”..
do you see anything in the arp table on the f5 (in tmsh ‘show net arp’, from bash ‘arp -n’) or your laptop? are any AFM or packet filter rules defined on the f5 that could prevent ICMP to/from the self-IP? have you tried running tcpdump on the f5?
f5 config should be vlan with necessary interface as untagged. unique self-ip should be assigned to that vlan as traffic-group-local-only.
you could try another interface
