I am haveing some trouble with this simple Irule and was hoping someone could help. All I have to do is check the incomming URL and see if it matches a reg ex. If it matches the reg ex, then pass the request on to “PoolB”.
The regular expression (as one of my devs has writtin it) looks like this:
A string comparison would be more efficient than a regex. If you really want to check if the postcode and email parameters are in the URI in a particular order you could use [string match *postcode=*email=* [HTTP::query]] to perform the test. Else if you want to check if the query string contains the two parameters in any order you could do two checks ([string match *postcode=*email=* [HTTP::query]] or [string match *email=*postcode=* [HTTP::query]]) or parse the parameters using URI::query (Click here)
Here is the first option:
Check if the query string contains anything postcode anything email anything or anything email anything postcode
if {([string match *postcode=*email=* [HTTP::query]] or [string match *email=*postcode=* [HTTP::query]])}{
Query string matched, so use PoolB
pool PoolB
Query string did not match, so use PoolA
pool PoolA
Here is the second option which parses the query string for the actual parameter values and checks if they have a length. If you don’t care whether the parameters have a value, you can remove the string length check on the values:
Check if the query string contains the postcode and email email parameters with lengths
if {([string length [URI::query [HTTP::query] postcode]] and [string length [URI::query [HTTP::query] email]])}{
pool PoolB
pool PoolA
