I’m very new to iRules, just got our LTM recently.
I setup a rule like this:
if {[string tolower [HTTP::uri]] starts_with “/jsfeatured.php”} {
pool jsfeatured_pool_80
} elseif {[string tolower [HTTP::uri]] starts_with “/js.php”} {
pool jobsearch_pool_80
My goal here is simple. If the user requests /jsfeatured.php, send them to the jsfeatured pool. If they’re requesting /js.php, send them to the jobsearch pool. Otherwise, let it fall through to the virtual server’s default pool.
Whats happening is requests to
/texis/jobseeker/
Are ending up in the jsfeatured pool, when they have a Referer: header of http://xxxxxx/jsfeatured.php
This just doesn’t seem like what I want _AT ALL_.
I tried making it
if {[string tolower [URI::query [HTTP::uri]]] starts_with “/jsfeatured.php”} {
But that made the rule never match the /jsfeatured.php, sending all of that traffic through to the default pool.
Am I missing something here? It doesn’t seem to me like HTTP::uri should be matching stuff in _any_ of the headers. I only want to match whats on that first line.
Thanks!
You are doing everything correctly and it should work. The value HTTP::uri does not contain any header values so odds are something else is amiss.
I would start by throwing in some logging
log local0. "Requested URI: [HTTP::uri]"
if {[string tolower [HTTP::uri]] starts_with "/jsfeatured.php"} {
log local0. "URI: [HTTP::uri] matched /jsfeatured.php"
} elseif {[string tolower [HTTP::uri]] starts_with "/js.php"} {
log local0. "URI: [HTTP::uri] matched /js.php"
log local0. "URI: [HTTP::uri] not matched"
Then look in the /var/log/ltm file and you’ll see the output of the log messages. In most cases, watching the logic flow can help diagnosing these problems.
Stupid question, but could the jsfeatured_pool_80 be the default pool for the virtual? If so, not overriding in the iRule would route there.
-Joe
FYI - this is caused be keepalive requests… If you don’t explicitly select the pool, the last pool selection stands. Since multiple requests, may come on the same connection, it’s a good idea to always have an else clause to pick the default pool.
Nope, you can grab the default pool and put it in a variable.
when CLIENT_ACCEPTED {
set default_pool [LB::server pool]
if {...} {
pool a
elseif {...} {
pool b
else {
pool $default_pool
Looks like unRuleY beat me to the punch…
-Joe
