If I want to filter out “?listall=1” and also “log=0” in the uri.
ex: http://testsite.com/test.aspx?listall=1?log=0
to http://testsite.com/test.aspx
How will the syntax look like ?
Best regards
Max
Best regards
Max
Hi Max,
You can use HTTP::query (Click here) to retrieve the full query string. You can parse individual parameter values using ‘URI::query [HTTP::uri] listall’ (Click here) to retrieve the value of the listall parameter. You can use string map to remove the parameter name=parameter value string.
If you read up on these commands and still have questions, reply here with what you’ve tried and what you’re seeing. Note that if the page which receives the requests accepts POST requests, an attacker could include the parameters in the post data. In that case, you’d need to collect the payload, inspect it and potentially rewrite it. To do this, you could use HTTP::collect (Click here) and HTTP::payload.
Aaron
One of your examples doesn’t look right to me
I have never seen a double query string before. Am I wrong?
CB
I’m guessing that’s just a typo in the post. The query string delimiter should be a question mark and the parameter value / parameter name delimiter is the &.
Aaron
I figured as much but I wanted to be sure.
ex: http://testsite.com/test.aspx?pageid=13&nocache=1&list=11
to http://testsite.com/test.aspx?pageid=13
I need to do some type of remove or filter before the url hit the webserver, and thats only for users from outside ip:s (they should not be able to use nocache=1 and list=nn=)
I am using an redirect at the moment.
ex2
if { [IP::addr [IP::remote_addr] equals 10.0.0.0/8] } {
else {
if { [string tolower [HTTP::uri]] contains “nocache=1”} {
HTTP::redirect “http://testsite.com/” }
if { [string tolower [HTTP::uri]] matches_regex {list*}} {
You could use something like this:
Check if client is not in internal range
if {not ([IP::addr [IP::remote_addr] equals 10.0.0.0/8])} {
Check if nocache=1 or list parameter is set with any value
if {[URI::query [HTTP::uri] nocache] == 1 or [URI::query [HTTP::uri] list] ne “”}
Redirect client?
But you’d also need to consider a client using encoding methods to bypass the filters. If the server supports the various encoding methods, clients could use (any combination of): numeral 1, Unicode: %u0031 or %u31, URL encoding: %31, .
Aaron
Thanks for the response!
I want the customer to come to the url but without the nocache=1 and list=nn.
If customer type:
http://testsite.com/test.aspx?pageid=130&nocache=1&listall=11
The only url thats should go to the webserver is
How can the redirect look like ?
with best regards
Max
Hi Max,
You can rewrite the URI inline using a rule like this. It’s untested, so try to add logging if you run into any issues. You may also want to add a check if you only need to look for the nocache and listall parameters in requests to specific paths. You could do this by adding a check for [string tolower [HTTP::path]] eq “/test.aspx”.
Debug logging
log local0. "[IP::client_addr]:[TCP::client_port]: New [HTTP::method] request to [HTTP::uri]"
Save copy of URI
set uri_tmp [HTTP::uri]
Check if URI contains nocache=1
if {[URI::query [HTTP::uri] nocache] == 1}{
Save updated URI with nocache removed
set uri_tmp [string map {nocache=1 ""} [HTTP::uri]]
Check if list parameter is set with any value
if {[URI::query [HTTP::uri] list] ne ""}{
Save updated URI without list parameter and value
set uri_tmp [string map [list "list=[URI::query [HTTP::uri] list]" ""] $uri_tmp]
Clean up any double delimiters from $uri_tmp and update the URI
HTTP::uri [string map {?& ? && &} $uri_tmp]
when HTTP_REQUEST priority 501 {
Debug logging
log local0. "[IP::client_addr]:[TCP::client_port]: Current URI: [HTTP::uri]"
Aaron
it works like a dream, Thanks!
Best regards
max
I also need to have an list of URI:s that i wan’t to block.
This is what I want to have, but I have problem with the syntax, and I would appreciate any help.
Check if URI contains something from the list in $::blockedurl
if {[URI::query [HTTP::uri] $::blockedurl }{
Save updated URI with $::blockedurl removed
set uri_tmp [string map {$::blockedurl “”} [HTTP::uri]] }
You can use matchclass (Click here) to compare one string against a datagroup.
What in the URI do you want to check against the class though? The path, query string, requested object, etc?
Aaron
I will take a look at he matchclass tonight.
example url
Here I want to filter (block) “test.aspx?pageid=13” so the url hitting the webserver will be just http://testsite.com
I also have 5more of the pageid:s that I want to block.
ex
http://testsite.com/test.aspx?pageid=33
http://testsite.com/test.aspx?pageid=42
You could parse the value of the pageid parameter using [URI::query [HTTP::uri] pageid] and then use matchclass to see if it’s defined in a datagroup named pageids_class:
if {[matchclass [URI::query [HTTP::uri] pageid] equals $::pageids_class]}{
pageid parameter value exists in the pageids_class datagroup
Aaron
Thanks again for all you help!
with best regards
Max
