Our Sharpoint server pool uses Windows Load Balancer Service, and worked fairly well. We want to put the server pool behind the F5. The web requests all work excellently. Our problem is incoming email.
We have several different apps that can send email to the Sharepoint servers and have that document post on a Sharepoint page. With WLBS, this works fine. Behind the F5, we get errors (posted below). We have tried several different configurations allowing SMTP to be forwarded by the F5 to the Sharepoint servers, but nothing seems to work.
I searched the forums and docs, but can’t find anything specific about our case. I tried the generic SMTP iRule from the Wiki, but it did not work for us (seems to do more than we want). Is there something I am missing? This seems like it would be simple to do …
Error symptoms are email queues to Sharepoint go up when pointed to the F5, and clear when pointed to a single server in the Sharepoint pool. If I use telnet and port 25, I get connected but an error after hitting enter:
HTTP/1.1 400 Bad Request
Content-Type: text/html
Date: Tue, 06 May 2008 13:37:24 GMT
Connection: close
Content-Length: 35
Bad Request (Invalid Verb)
Connection to host lost.
Sorry so long! Any help is appreciated.
Thanks!
I should mention that the IIS servers for Sharepoint use IP headers to route the traffic … all the F5 does it answer to the virtual server IP and forward to the Sharepoint server pool. No rules.
