Hi
2/ problem 1
i had to configure the system manually based on the Iapp as the client need OTP authentication (LTM, APM, ASM all active). i think there settings match the template but the SharePoint user receive “object moved” (302) error pages. This seams to happen on “http redirect pages”, IE 10/11 and almost all the time with going from “/” to /SitesPages/Home.aspx at logon time. The screen the user see is very corrupted with F5 text before the message and encoded test after it. The user can just refresh the screen to get the correct page. I am thinking it’s a connection issues between the F5 and SharePoint web server. I have a Irule to force a redirect on a 302 error page for the logon but i not sure how to fix it for other pages. Anyone any ideas.
2/ problem 2.
i have the “acceleration” profile (as define in the template) enable and the user could not see any documents for directory listing in share point. I disable the profile. Any idea what wrong?
3/ Problem 3.
i have the two “SignOut.aspx” Url in the logout URL but they did not work. i added in the Irule a force a logout but this should not be happening. i idea what i have configure incorrectly?
