Hi, we have SharePoint 2010 farm with 3 front-end servers load balanced via F5 BIG-IP. We recently had request that need to encrypt our SharePoint site with SSL. Our F5 admin setup SSL offloading and I follow all the steps in F5-SharePoint setup manual f5-sharepoint-2010-dg.pdf. For some reason our homepage always not encrypted and other areas were encrypted. Why our homepage wasn’t encrypted? Are there any additional steps that I need or F5 administrator to configure?
Thanks Tee
If I had to put money on it, I’d say SharePoint’s alternate access mapping (AAM) is getting in the way. Three questions:
Do you get an immediate redirect to an HTTP:// address when you access via HTTPS://?
Do you have an HTTP VIP for this site?
Do all of the resources (homepage and other areas) have the same host name and go through the same VIP?
If I enter http:// it will stay this way when I browse sites, pages. Same case for https://
If you go directly to the HTTPS:// version of the homepage, do you stay on the HTTPS:// site? What other indication do you have that the homepage is “always not encrypted”?
If I go to the https:// version of the homepage, it will stay on http://, however, I don’t see SSL lock icon:
image_182885 (320 KB)
and if I go to subsite like news: it contain SSL lock icon
image_182885 (115 KB)
Interesting. So if you’re certain that everything is going through the same VIP and is using the same host name, can you:
Run a capture on the browser side (ie. HTTPWatch or Fiddler) and observe the URLs that the browser is requesting. Are they all HTTPS?
Disable the port 80 VIP.
