Sharepoint 2007 - "Export to Spreadsheet" not working over HTTPS
We have deployed sharepoint 2007 behind F5 LTM. Sharepoint uses a feature in which export to excel which is not working for us in HTTPS environment. Here is the info which i got export to excel feature.
9. Leverage Excel for data management
Exporting data to Excel is well-supported in SharePoint and makes graphing and printing convenient (via the Print with Excel and Chart with Excel options). But it’s also possible (and may often be desirable) to export data to Excel just for the sake of manageability. The Excel Export function creates an Excel Web query linking to the original data. In this way, you can create spreadsheets that will accept data, and then push that data to SharePoint.
This can be done by generating an Excel spreadsheet, then linking the spreadsheet to SharePoint (by using Export and Link to Excel from a Datasheet Task Pane). Once this is done, data can be entered into the spreadsheet and pushed from the spreadsheet to Excel with the Synchronize List option.
Everything works fine when the VS is configured on HTTP mode. The servers are listening on port 80. The problem is with HTTPS connection only. In standard setup we are redirecting all HTTP requests to HTTPS.
POST /it/sites001/_vti_bin/lists.asmx HTTP/1.1
Content-Type: text/xml; charset=utf-8
SOAPAction: http://schemas.microsoft.com/sharepoint/soap/GetListAndView
X-Office-Version: 12.0.6020
User-Agent: Microsoft Office/12.0 (Windows NT 5.1; Microsoft Office Excel 12.0.6020; Pro)
Host: mysite.mydomain.com
Content-Length: 340
Connection: Keep-Alive
Cache-Control: no-cache
Cookie: MSOWebPartPage_AnonymousAccessCookie=80
{C5B5DCE4-BF3E-4715-9BD8-1A8AA36A5064}
{38C6017E-7CE6-4AB3-B3F6-1280E26CD806}
HTTP/1.0 302 Found
Location: https://mysite.mydomain.com/it/sites001/\_vti\_bin/lists.asmx
Server: BigIP
Content-Length: 0
If i user the uri part above and connect to HTTPS then it is not working.
This is the .iqy file which gets generated when you do “export to excel”
WEB
1
http://mysite.mydomain.com/it/sites001/\_vti\_bin/owssvr.dll?XMLDATA=1&List={C5B5DCE4-BF3E-4715-9BD8-1A8AA36A5064}&View={38C6017E-7CE6-4AB3-B3F6-1280E26CD806}&RowLimit=0&RootFolder=%2Fit%2Fsites001%2FLists%2FSite%20Provisioning%20List
Selection={C5B5DCE4-BF3E-4715-9BD8-1A8AA36A5064}-{38C6017E-7CE6-4AB3-B3F6-1280E26CD806}
EditWebPage=
Formatting=None
PreFormattedTextToColumns=True
ConsecutiveDelimitersAsOne=True
SingleBlockTextImport=False
DisableDateRecognition=False
DisableRedirections=False
SharePointApplication=http://intranetpp.bmc.com/it/sites001/\_vti\_bin
SharePointListView={38C6017E-7CE6-4AB3-B3F6-1280E26CD806}
SharePointListName={C5B5DCE4-BF3E-4715-9BD8-1A8AA36A5064}
RootFolder=/it/sites001/Lists/Site Provisioning List
Can someone also help to understand how sharepoint work when you click on links on the site. If you remove http → https then the pages remain as http only. Is there any way to make sure that https setup remain all the time?
I also read about url rewrite from http → https. Is this necessary?
I would appreciate getting some help on this. We have production issues which needs to resolved ASAP.
Thanks in advance,
Vishal
Hi Vishal,
We are also facing the same issue with “Export to Spreadsheet” and also with search scopes where “This List” is not shown when we use https.Both these option works fine with http.
Did you got any fix for your issue ?
If so I would appreciate getting some help on this
Thanks for your help
Ranjith
Hi Ranjith,
Take a look at Vishal’s other post here for a few suggestions:
http://devcentral.f5.com/Default.aspx?tabid=53&forumid=5&tpage=1&view=topic&postid=32617
Aaron
Looks like yes we found the fix. We are suspecting issue with Alternate Access Mapping (AAM) configured on Sharepoint. Basically in our setup we are doing SSL offloading using LTM and doing HTTP to HTTPS redirection for HTTP requests. We found AAM configured on Sharepoint which was converting HTTP to HTTPS. This is basically not required since the redirection is done on LTM and Sharepoint should be taking care of HTTP requests only. Initial results were positive and we didnt see issue with “List” by removing HTTP to HTTPS mapping on sharepoint. The app teams are going to test it thoroughly. I will share the results once available.
Wouldn’t you want to configure the AAM to use HTTPS references so you don’t need to use LTM to rewrite the redirects? Also, the response payload references should be HTTPS when using AAM.
Aaron
Hi Vishal,
As you said we tried to remove HTTP to HTTPS redirection from the AAM. Due to this we ran into some problems like issues with search and the application fails to render sometimes.As part of our initial testing these are the issues we found and I will keep you posted on the same.
Ranjith
