sfp serial number
how can I get the serial number from the sfp´s in my remote system?
Viprion 2400 Blade 2100 Version 11.1.0.1953.0-HF1
I only found
tmsh show sys hardware,
but shows only the chassi numbers
Thanks for help
Regards,
Markus
Hi Markus,
It’s not currently possible to get the serial number or part number of the modules remotely--you need to pull the modules to confirm this. Here’s a request for enhancement you can reference with F5 Support for this:
Bug 382312 - RFE: Expose SFP/SFP+/QSFP “part number” and “Laser Emitter” via tmsh
You can open a case with F5 Support referencing BZ382312 to raise the visibility of the request.
Aaron
Hi Aaron,
Thanks for the information. I will open a support case raise the visibility
Have a nice week
Markus
