Hello guys.
I have to multiplex several client connections into a single server connection. I’ve tried using OneConnect profile but it just reuse the connection and when I try to send 2 simultaneous connections I’ve ended with 2 distinct server connections.
The connection is TCP based and it is an ISO format so I have something like an unique id per client recorded on the payload (in the request and response as well).
Today they are using a LINUX based system and a software that does the multiplex. I’m trying to do the same job here.
I was thinking of receiving all client connections letting just the first one to the server, using oneconnect to re-use it. After the first connection, I was thinking of receiving all packets from the other connections and relaying it to the first connection.
I could use global variables to to this but I would need to create an wait and check iRule that as stated several times on DevCentral it’s not possible.
Has anyone have an idea how I can do this?
Thanks!!!
