Setting up SAML as F5 IDP to work with Amazon Cognito
Has anyone setup F5 SAML to work with Amazon Cognito.  I’m getting error message “Invalid RelayState from Identity Provider”.
I tried with different endpoint for Relay State.  No Luck.
Local IdP ServicesIdP Entity ID: https://test01.caci.com/cognito Assertion Settions:
  • Assertion Subject Type: Persistent Identifier
  • Assertion Subject Value: %{sessionlogon.last.username)
  • Authentication Context Class Reference: urn:oasis:names:tc:SAML:2.0:nameid-format:persistent
SAML attributes:
External SP Connectors Configuration:Service Provider Entity ID: urn:amazon:cognito:sp:us-gov-west-1_PewQe5b4rRelay State: ???Assertion Consumer Services:  https://test01.auth-fips.us-gov-west-1.amazoncognito.com/saml2/idpresponse
Metadata XML file has been uploaded to Amazon Cognitio
Have you turned logging on and reviewed the auth logs yet?
I hope you have insert a dot here:
  • Assertion Subject Value: %{session.logon.last.username)
For relay state you could add the following variable: %{session.server.landinguri}
Cheers,
Kees
Hi  @jdewing   - did the answers from Kees or Aubrey help you out? Are you still looking for a solution? Did you solve it another way?
