Hi all, is there a way to set a maximum number of requests in ASM v11.3 or will an iRule need to be created for it? Does anyone have any suggestions?
Thanks!
Thanks!
While you can limit the number of HTTP requests per connection, that isn’t done in ASM. It’s a function of the HTTP profile, specifically the ‘Maximum Requests’ setting. The default is ‘0’, which means ‘unlimited’.
