setting cookie size
Hi, How can I set cookie size value in f5 for example ,if the size exceed more than 2Kb do not process it Thanks
You can try this irule, which removes the cookie header if its total length exceeds 2K:
    if { [HTTP::header exists Cookie] } {
        if { [string length [HTTP::header Cookie]] > 2048 } {
            HTTP::header remove Cookie
