Setting Client Certificate Authentication on F5 BigIP
Hi all,
Currently we are using a SharePoint 2013 farm with 3 Web Front End servers load-balanced with BigIP. The customer wants to configure client certificate authentication (require) to enhance the security of the SharePoint Farm. So we are thinking about setting the certificate authentication on BIG-IP.
Since we do not know much with BigIP configuration, so is there anyone can help us to accomplish this? Any helps would be great appreciated.
You can check that articles:
Regards
you may try using an APM policy with ‘client cert inspection’ agent in it. Do you have any authentication setup after client cert is validated?
Yes, we want to use both client cert authentication (validate first) and then username/password to authenticate users.
