I am having trouble figuring out how to point a virtual to an iRule through the bigpipe command line interface.
on the old Big-IP, I would do: $ bigpipe virtual use rule
this doesn’t seem to work on the LTM 9.x.
Does anyone know the syntax, or can point me in the right direction? I searched the documents for bigpipe and can’t find an answer.
-Corey
thanks ill give it a try!
JRahm
4
if you want it to persist through a reboot you’ll need a “b save” as well
Suppose a virtual server is already pointing to 2 iRules, then how do i attach the 3rd iRule to the same virtual server through command prompt.
Does the command b virtual vitusl_name rule rule_name overwrites all the previous iRule assignments.
Version:10.2.0 HF2
Hardware:Viprion
Regards,
Sid.
Yes, the command will overwrite, use add/delete:
b virtual rules add
b virtual rules delete
