I am new to F5 and wanted to learning about the sync failover configuration. In my lab I have two standalone BIG-IP 13.0.0 Build 2.0.1671 Hotfix HF2 servers. I wanted to set up LTM module and then Configuring a Sync-Failover device. Can someone validate this plan? First configure f5 serve A completely and get the needed LTM modules and then set up load balancing server on the apps . once this is all virtual server are load balanced and tested . I want to add another server and configure Sync Fail over devices. This is the point I want to ask questions. Is this possible to do or first I need to configure basic f5 and then configure sync fail over . Once this is tested , I should configure the virtual servers for ltm module.
Does the order of configuration important.
Can someone point me in the correct direction or recommend approach. Any pointer is appreaciated.
