set monitor state
I am trying to set a pool member monitor state to disabled. I think that I am very close with this code:
private void SetMonitorState(string pool, string memberaddr, long memberport)
string[] pool_names = new string[] { pool };
LocalLBPoolMemberMemberMonitorState[][] monitor_states;
monitor_states = new iControl.LocalLBPoolMemberMemberMonitorState[2][];
monitor_states[0] = new LocalLBPoolMemberMemberMonitorState[1];
monitor_states[0][0].member = new iControl.CommonIPPortDefinition();
monitor_states[0][0].member.address = memberaddr;
monitor_states[0][0].member.port = memberport;
monitor_states[0][0].monitor_state = CommonEnabledState.STATE_DISABLED;
m_interfaces.LocalLBPoolMember.set_monitor_state(pool_names, monitor_states);
I get a “Object reference not set to an instance of an object.” error on the line -
I would be very grateful, if someone could point out my mistake.
You are close. You haven’t allocated a value for the monitor_states[ 0 ][ 0 ] value. This should work for you:
   // Allocate a 2-d array
   monitor_states = new iControl.LocalLBPoolMemberMemberMonitorState[ 1 ][];
   // Allocate the first dimensions value to a 1-d array of size 1
   monitor_states[ 0 ] = new iControl.LocalLBPoolMemberMemberMonitorState[ 1 ];
   // Allocate the value for the entry in the first element of the second dimension
   monitor_states[ 0 ][ 0 ] = new iControl.LocalLBPoolMemberMemberMonitorState();
   // Allocate the IPPortDefinition
   monitor_states[ 0 ][ 0 ].member = new iControl.CommonIPPortDefinition();
   monitor_states[ 0 ][ 0 ].member.address = memberaddr;
   monitor_states[ 0 ][ 0 ].member.port = memberport;
   monitor_states[ 0 ][ 0 ].monitor_state = CommonEnabledState.STATE_DISABLED;
BTW, sorry for how the forum munges brackets followed by numbers. I’m going to have to track that down one of these days.
-Joe
Thanks again Joe!
Regarding my post, “pool member forced offline”, I see where my mistake was. I was using LocalLBPoolMemberMemberSessionState. What I really wanted was LocalLBPoolMemberMemberMonitorState. I suspect that I was not communicating clearly in the post.
I’m very grateful for your help!!
