Sessions Persistence Broken in 12.1.2
BigIP persistence cookie changing in middle of session in 12.1.2 It was working in 11 code.
Our mobile apps are breaking because of this behaviour, anyone faced this issue with session persistence in 12.1.2.
JSESSIONID=sSJ7sFp3YgPDIky3qCPhoTRqm7tkuSNafFi5S9QdB583Ks7Omcp-!1638640624; ADD_TO_CART_COOKIE=Y; BIGipServerstg-pl-att-L7=367794954.2848.0000;
These are the cookies we use Jessionid from app and BigIpServerstg cookie is from F5.
Any chance httponly cookie attribute, which is turned on by default in 12 but not in 11, is screwing this up?
Yes Httponly Attribute is enabled. Do we need to disable that one ?
Disable it and test.
We are seeing similar issues after upgrading from 11.1 to 12.1. It looks from our testing like “persist none” is not working - after calling it the F5s are still setting the persistence cookie from the persistence profile. We are working around it by deleting the cookie from the response if persistence should be turned off.
I diabled it, same issue.
We are doing similar workaround outside of F5. F5 should really address this issue.
