I want to ssl encryption between F5 and back end server. i have imported certificate on server(test.abc.com). in F5 i have seen defult serverssl profile. what are the mandatory changes i have to do in the serverssl profile
- Create a loadbalacing pool with members - node + ssl service port and https monitor. Check this goes green.
- Add serverssl profile to VS.
- Change default pool for the VS.
You can use the serverssl profile without any changes, unless your backend has some specific SSL settings.
