Serverside Mutual TLS
Hi, can i configure Mutual TLS between F5 and poolmember (ServerSide) ? Do you have any example configuration ? Regards, Nick
I think this article will help you:
Check out Overview of Server SSL Profile
So, you’ll need to attach a server SSL profile to your virtual server. Then you can add a certificate/key pair so the bigip can act as a client and authenticate to the pool member. Also, in the server authentication section you can specify that the pool member authenticates itself to the bigip my changing server certificate to Require and adding the CN that the pool member will present.
Hope this helps,
N
