I’m currently implementing an LTM config with a virtual server pointing to a real server which only supports TLS 1.0 and old ciphers.
I managed to get it working using the following config :
ServerSSL profile : based on serverssl-insecure-compatible, cipher list : !SSLv2:!TLSv1_2:!TLSv1_1:!EXPORT:!DH:RSA+RC4:RSA+AES:RSA+DES:RSA+3DES:ECDHE+AES:ECDHE+3DES:@SPEED (I had to disable TLS v1.1 and 1.2 because the client hello used SSL version 3.3 and the server sent a fatal alert for incompatible protocol version)
HTTPS monitor :
Send String : GET /mypath/ HTTP/1.1\r\nHost: mysite.com\r\nConnection: close\r\n\r\n
Receive string : 302 Moved temporarily (the site redirects unauthenticated sessions to the authentication portal)
cipher list : AES-256-SHA
I ran a script to determine supported ciphers on the server and found the following : Testing AES256-SHA…YES Testing AES128-SHA…YES Testing ADH-DES-CBC3-SHA…YES Testing ADH-DES-CBC-SHA…YES Testing EXP-ADH-DES-CBC-SHA…YES Testing ADH-RC4-MD5…YES Testing EXP-ADH-RC4-MD5…YES Testing EDH-RSA-DES-CBC3-SHA…YES Testing EDH-RSA-DES-CBC-SHA…YES Testing EXP-EDH-RSA-DES-CBC-SHA…YES Testing DES-CBC3-SHA…YES Testing DES-CBC-SHA…YES Testing EXP-DES-CBC-SHA…YES Testing RC4-SHA…YES Testing RC4-MD5…YES Testing EXP-RC4-MD5…YES Testing EXP-RC4-MD5…YES Testing RC4-MD5…YES
When my HTTPS monitor is set with AES-256-SHA as a cipher list, I can connect. However, I’d like to be less specific than that because I don’t want the monitor to fail because the sysadmin or application admin upgraded to a newer version or changes the list of supported ciphers. But when I use the same cipher list that I used in the SSL server profile, it fails…
Any idea why ?
Enabling bigd.debug only showed : unable to connect; giving up [ addr=::ffff:x.x.x.x:yyyy srcaddr=::ffff:a.a.a.a:bbbb ]
and ssldump shows a successful SSL negociation with Application data. I don’t have access to the server’s private key so I can’t decrypt.
Neither cURL/OpenSSL, nor apparently the monitor cipher list likes the @SPEED option, plus the underscores in the clientSSL profile need to be changed to periods.
I was surprised that the client hello was sent with protocol version 3.1 (TLS 1.0) whereas the actual connection to the server uses protocol version 3.3 (TLS 1.2) by default (if I don’t specify !TLSv1_2 in the cipher string).
Obviously, the monitor does not use the same SSL implementation as the SSL server profiles …
Thanks for your help Kevin !
Tom
PS: this is the behaviour on 11.4.1 HF2, I’ll try 11.5.0 soon, I might get different results.
I just used my version of the string on an 11.5 box, so I’m pretty certain that works. One alternative might also be to do this in an external script monitor and use cURL with the --ciphers option.
