server ssl connection problem after upgrading to 12.0 version
Hi all,
i have virtual server configured like this: - own profile ssl_client - irule with url wrapping - profile server_ssl to connection in ssl to backend server (jboss)
with the 11.3 version all works fine. When i upgraded my F5 to version 12.0 and import all configurations this virtual server fail to connect to backend servers in https.
something is changed with 12.0 in server_ssl profile?
I try to restore the 11.3 version (using the switchboot) and all return to works.
i switched again to 12.0 and continue to not work. i try to create my own server_ssl profile with the same root CA of the backend server, but still not work.
can anyone have ideas to resolve this issue?
thanks a lot
I think the issue in SSL ciphers wich used in the default SSL profiles, they differ in 11.3 and 12.0. You need to check the ciphers suite in server ssl profile.
SSL ciphers used in the default SSL profiles 404 Page not found | BIG-IP Documentation
thank u for ur reply… i’m starting to test usign my own server ssl profile with the cypher suite defined in the 11.3 version. i will let u know if it works. thanks
