Hello All,
I have been facing a issue where I have one SSL application configured. I am using default client and server ssl profile. client side SSL connection is establishing, but in server side connection I am getting only 3-way handshake and push messages from self-IP, SSL handshake is not happening. however the monitor I have configured for that pool is HTTPS based, where I am fetching the same URL over some random port via SSL, which is working fine. Below is the decrypted Wireshark trace from LB: -
But when user is trying to access the application, I cannot see server side SSL handshake.
Any suggestions?
Is this capture coming from the request or the monitor. And if the monitor is it marking the pool member down?
Attached is the capture for client traffic.
We don’t have SSL handshake happened between server side traffic.
I just checked secure handshakes/renegotiations for clientssl and serverssl. there are no SSL handshakes/renegotiations for serverssl. Below is the output.
I have also tried changing Renegotiations setting from require strict to request, but no luck.
It seems that server side SSL handshake is failing due to “bad server public key, p or /and q.”
Below is the screenshot: -
Any suggestion, how to resolve it?
If I’ve got your capture right - That looks like client (BigIP in this case) is closing the connection down - Due to an incorrect key being supplied by the server. The Server SSL profile - Are you using the same key/cert as client side ?
