Serial No for Opening Case
Dear All,
hope you doing well,
I have one simple question about serial number which I can use it to open the case, before I used last seven digits and it was working fine, now am trying to open a case using same serial No, but it showing this message ( Database Error -- Faulty Unit Has No Entitlement - No Active Entitlement found for “OODFTDO”).
Please would you support me to know how I can get this digits from Serial No.
BTW am new in this field.
Best Regards,
You should also use license key.
Your BIG-IP support contract seems to have expired about a week ago. Thus you may not be able to open a support case.
 F5 Product Information for ZOODFTDO
  F5 Product            : F5-BIG-LTM-VE-1G-V13 BIG-IP VIRTUAL EDITION: LTM LICENSE 1GBPS (V11.4.1
  Usage                 : Production
  Product Order Status  : Sales
  License Time Limit    : N/A
 Service and Warranty Information
  Entitled Service      : 09-27-2015 - 09-26-2016 (F5-SVC-BIG-VE+PREL13)
  Warranty End Date     : 09-25-2016
You can check the support status with a serial number or license key (even with the last part of the license key) at F5 Licensing tools --> Product Information Request
