Sent to ouside syslog using iRule
Hi all,
My first time here.
Can anyone help to erite an irule which send out log each time an IP is connected to virt.(indlude th src ip addv and des real server)
I got complaint that at the application log they sees same ip jump btween two reals server despite i am using a source Ip PRESIST PROFILE.
TNX all
I believe you can use the following sample code.
http://devcentral.f5.com/wiki/default.aspx/iRules/In\_Depth\_Traffic\_Analysis\_via\_iRule.html
Just cut out information you don’t want to log
I hope this helps
CB
In addition to CB’s useful suggestion, you can also use the 'log ’ option in 9.4 and higher to bypass syslog-ng and send syslog messages directly to a remote syslog server:
iRules Update: The “log” command gets new options
http://devcentral.f5.com/Default.aspx?tabid=63&articleType=ArticleView&articleId=190
And here is another Codeshare example which logs IP:port details for TCP/HTTP/UDP VIPs:
http://devcentral.f5.com/wiki/default.aspx/iRules/LogHttpTcpUdpToSyslogng
Aaron
Good ones Aaron :wink:
