Sending HTTP request headers via TCP or HTTP to another machine
Hi, I’m trying to catch HTTP requests from a virtual server, and send the HTTP headers to a separate machine. I looked into iRules but didn’t find the way. Is it possible? Is there a better way than iRules?
You can use sideband connections. Here you can find an example :
https://devcentral.f5.com/wiki/irules.sideband.ashx
https://devcentral.f5.com/codeshare?sid=686
Sideband connections allow you to send a request to a specific destination.
You can also use the clone pool feature to clone requests on the virtual server.
Thanks, but I’m actually trying to edit the request before it arrives to the server and then send it to the server,and edit the response as well, before it arrives to the client, and send it to the clinet. all the editing needs to happen on a diffrent machine that runs C++ written filters.
Hi, so sideband connection is the right feature for your need
