Send only Audit logs to remote syslog
we have a qradar server where we will send the F5 logs to it. We only want the Audit logs to be sent to qRadar.
How can I filter what type of logs I sent to the remote syslog server (qradar), so we only send Audit logs to it.
Thanks a lot.
SANTS.
Hi SANTS, in 11.6 (and earlier, though I don’t know specifically which version it was introduced) you can create log filters, destinations, and publishers right in the GUI.
1st step: system->logs->configuration->log destination 2nd step: system->logs->configuration->log publisher 3rd step: system->logs->configuration->log filters
If on earlier systems, you can configure in tmsh/syslogd as well (good info in this article)
Thanks a lot Jason. I am forced to use High-speed logging? (So I cannot use the management interface to send logging traffic?)?
thanks.
Regards,
SANTS
Thanks Jason, but when you press remote syslog, you are forced to put the High Speed Syslog afterwards.
How can I over pass this?
thanks.
SANTS
Right..but that just means you are using HSL under the hood of BIG-IP, if you select syslog formatting, it won’t just be the RAW format typical of HSL. All that’s required for that is to define a pool (can be one member->your syslog server) and then select it as your destination
yes I will use a pool of 1 server. My question is then, I can send the traffic through the management interface or I am forced to use a data interface? thanks a lot. SANTS
