send a client message in a long tcp connection to multi-server at the same time
It was said that Bigip V9 is possible to break out client transactions and load-balances them to different servers using one connect as below:
NCPDP transaction rule
rule NCPDP_transaction {
   when CLIENT_ACCEPTED {
      set request_len 0
      set request_hdr ""
      set request_pending 0
      set response_len 0
      TCP::collect
   when CLIENT_DATA {
      set tlen [TCP::offset]
       Haven't found the start of the transaction yet
      if { $request_len == 0 } {
         set trans [TCP::payload]
         if { not ( $trans starts_with "\002" ) } {
             This should really never happen
            log local0. "Missing request STX - [IP::remote_addr]:[TCP::remote_port]"
            set index [string first "\002" $trans]
            if { $index == -1 } {
                No STX found - drop everything we've collected so far.
               TCP::payload replace 0 $tlen ""
               TCP::collect
               return
             Drop any data up to the STX
            TCP::payload replace 0 $index ""
          Wait until we've got a whole transaction header
         if { $tlen < 25 } {
            TCP::collect
            return
         scan [string range $trans 1 6] "%d" request_len
         set request_hdr [string range $trans 7 24]
          Need to account for STX/ETX characters in the total transaction length
         incr request_len 2
       Received all of the transaction
      if { $tlen >= $request_len and not $request_pending } {
          Release the current transaction
         TCP::release $request_len
          Hold any additional requests until we get the response
         set request_pending 1
          Reset current transaction
         set request_len 0
       Always keep collecting
      TCP::collect
   when LB_FAILED {
      LB::reselect
   when SERVER_CONNECTED {
      TCP::collect
   when SERVER_DATA {
      if { $response_len == 0 } {
          This should never happen
            log local0. "Missing response STX - [IP::remote_addr]:[TCP::remote_port]"
                No STX found - just drop everything we've collected so far.
               TCP::collect
               return
          Wait until we've got the whole transaction header
         if { $tlen < 25 } {
            TCP::collect
            return
         scan [string range $trans 1 6] "%d" response_len
         set response_hdr [string range $trans 7 24]
         incr response_len 2
       Received all of the transaction response
      if { $tlen >= $response_len } {
         if { $request_pending } {
             Release the current response and invoke a detach
            TCP::release $response_len
            set response_len 0
             Trigger USER_RESPONSE on the clientside so we can detach, etc.
            TCP::notify response
             Received a response while there was no pending request - drop it
            log local0. "Received unsolicited response from [IP::remote_addr]:[TCP::remote_port], len: $response_len, hdr: $response_hdr"
            TCP::payload replace 0 $response_len ""
            set response_len 0
      TCP::collect
   when USER_RESPONSE {
       Detach the server so the next request can be re-load balanced
      LB::detach
       Is the clientside already holding another request?
          Release any future request
      } elseif { [TCP::offset] >= $request_len } {
         set request_len 0
Now I wonder whether it is possible for Bigip v9 to send a selected transaction request in one long alive tcp connection to multi-server at the same time. For example, there is a transaction request AAAAABBBBBAAAA sent from client side, it was hoped all the nodes can receive this request.
Unfortunately, that’s not yet possible. An iRule can make an LB decision, but there is no way to open multiple connections.
This post is almost a year old…
Has anything changed since this post? Can BIG-IP LB Transactions inside of a connection if we can identify the transaction?
