Self IP on wrong VLAN
Any help is appreciated. I have inadvertantly associated the self IP of the device with a VLAN which I created. I am trying to return to the original configuration. When I attempt to change the VLAN associated with this particular self IP back to internal, the change will not stay when I click “update”. I have 2 Big IPs with failover and I am making these changes on the standby device. Any ideas? Thanks!
Check to see if “Strict Updates” is enabled.
Application Services properties screen, and select the Advanced view , the Strict Updates field is shown
I verified “Strict Updates” is enabled. Still not able to change back to internal.
Disable it then make your change then re enable
Try this: 404 Page not found | BIG-IP Documentation
Problem solved. I removed VLAN’s which were in the VLAN group, which I created. After removing the VLAN’s, I deleted the VLAN group and could then configure the correct VLANs for the selfp IPs. Now need to learn how to set up load balancing for new servers. Thank you for your help, Daren!
Good news Albertz! Thanks for sharing the answer.
