Selective SNAT
Problem this snippet solves:
iRule that SNATS based on host address and port while just forwarding everything else.
Code :
class Hosts {
   host 10.1.1.1
   network 10.10.0.0/16
class Ports {
   22
   80
   110
when CLIENT_ACCEPTED {
   # Check if the client IP address is a member of the address data group named Hosts
   if { [matchclass [IP::client_addr] equals Hosts]} {
      # Check if the client's destination port is in the Ports integer data group
      if { [matchclass [TCP::local_port] equals Ports]} {
         # snat using this source address
         snat 192.168.100.12
         # Exit this event to avoid disabling SNAT below
         return
   # Default action is to not SNAT
   snat none
# Here is an elegant example from j.thomson to SNAT only if the client and destination are on the same /24 subnet. (from this post: https://devcentral.f5.com/s/default.aspx?tabid=53&view=topic&forumid=5&postid=2379)
when LB_SELECTED {
   if {[IP::addr "[IP::client_addr]/24" equals "[LB::server addr]/24"]} {
      snat automap
# And another option for using SNAT only if the client IP is a node in the pool:
   # Check if the client IP address is a node in the VIP's default pool
   if {[matchclass [IP::client_addr] equals [active_nodes -list [LB::server pool]]]}{
      log local0. "SNAT'ing for [IP::client_addr], member of pool [LB::server pool]"
      snat automap
# And another for when the client and member servers are on the same /24 subnet
when LB_SELECTED {
   if {[IP::addr "[IP::client_addr]/24" equals "[active_nodes -list [LB::server pool]]/24"]} {
      snat automap
