Selective HTTPS redirection
I am having following requirement in which the servers in the pool should talk to the virtual server using HTTP only while all other users should redirect to HTTPS.
The requirement for servers talking to the VS was fulfilled using the following iRule
when CLIENT_ACCEPTED {
  checks to see if client_addr = any in the class
  fmw_nodes class has servers in the pool
  if { [matchclass [IP::client_addr] equals $::fmw_nodes]} {
            snat 192.168.253.250
            pool fwm-uat.bmc.com
The HTTP → HTTPS redirection is configured using following iRule
     HTTP::redirect https://[HTTP::host][HTTP::uri]
How does the iRule evaluation takes place when you have more than one iRules?
I would appreciate any help in this regards. I am new to BIG-IP LTM
Thanks in advance
iRules are processed in the order they have been set in the VS configuration.
So if each iRule use the same variable, ensure you got the order correctly.
Usually it’s recommended if possible to merge several iRules in one. It’s easier to troubleshoot and you can look at the code in one shot.
If you are talking about the order of processing of your two iRules you configured above it will be:
CLIENT_ACCEPTED then HTTP_REQUEST
CLIENT_ACCEPTED is triggered after the TCP connection is established.
HTTP_REQUEST will be triggered each time the client sends a request to the server.
HTH
N.
If you see the code i have used for SNAT it sends the traffic pool if the client ip doesnt match using the matchclass. If that is the case and assume i have 2 rules 1. SNAT 2. HTTP_Request, will it go to the second rule? Is it necessary to use “else” after “if”
Yes it will go to the HTTP_REQUEST anyway.
What happens is:
Your CLIENT_ACCEPTED event will say: when you’ll forward the request hide the Source IP with this one.
Then your HTTP_REQUEST will be trigger and it will redirect the user to HTTPS. In this case you didn’t forward anything since you just send a redirect to the user so the snat request won’t be effective and used.
With both iRules, anyone talking through HTTP should be redirected through HTTPS.
If you want not to redirect the servers you should merge everything in the HTTP_REQUEST to obtain something like this :
if{ [TCP::local_port] == 80} } {
N.
} else
In the first part it should snat and send the traffic to pool also. Do i need to mention the pool statement or it will use the pool configured in Virtual Server?
if you don’t use any pool command, it will use the default pool configured in the VS
What is recommended method for SNAT? using SNAT configuration option via web or iRule?
if you need to apply SNAT to only specific client the best method is to use an iRule. Same thing if you need to use different SNAT configuration depending on the clients
If you need to do SNAT for all connection, use the GUI it will be easier to maintain.
Thanks for all your help. I will try and let you know.
Can you post your iRule ?
Otherwise what you can do to troubleshoot is to use the log command to print information during the processing of your iRule.
It may help you to see what’s happening.
The logging will appear in /var/log/ltm
when HTTP_REQUEST
if{[matchclass[IP::client_addr] equals $::fmw_nodes]}
else
Here is what i have found in the logs
TCL error: Rule fmw-test - invalid command name “matchclass192.168.253.250” while executing “matchclass[IP::client_addr] equals $::fmw_nodes”
Mar 3 09:31:09 tmm tmm[1089]: 01220001:3: TCL error: Rule fmw-test - invalid command name “matchclass192.168.253.250” while executing “matchclass[IP::client_addr] equals $::fmw_nodes”
Mar 3 09:31:19 tmm tmm[1089]: 01220001:3: TCL error: Rule fmw-test - invalid command name “matchclass192.168.253.250” while executing “matchclass[IP::client_addr] equals $::fmw_nodes”
Mar 3 09:31:29 tmm tmm[1089]: 01220001:3: TCL error: Rule fmw-test - invalid command name “matchclass192.168.253.250” while executing “matchclass[IP::client_addr] equals $::fmw_nodes”
Mar 3 09:31:31 tmm tmm[1089]: 01220001:3: TCL error: Rule fmw-test - invalid command name “matchclass137.72.254.231” while executing “matchclass[IP::client_addr] equals $::fmw_nodes”
Mar 3 09:31:39 tmm tmm[1089]: 01220001:3: TCL error: Rule fmw-test - invalid command name “matchclass192.168.253.250” while executing “matchclass[IP::client_addr] equals $::fmw_nodes”
Mar 3 09:31:42 tmm tmm[1089]: 01220001:3: TCL error: Rule fmw-test - invalid command name “matchclass137.72.254.231” while executing “matchclass[IP::client_addr] equals $::fmw_nodes”
Mar 3 09:31:49 tmm tmm[1089]: 01220001:3: TCL error: Rule fmw-test - invalid command name “matchclass192.168.253.250” while executing “matchclass[IP::client_addr] equals $::fmw_nodes”
You need a space between matchclass and [IP::client_addr]
Thanks. I fixed it. Now i am getting the webpage however it is not getting redirected to HTTPS my machine. My machine’s ip is different that what is mentioned in “fmw_nodes”. I am seeing my machines ip in the log.
Hmm,
Can you do the following?
when HTTP_REQUEST
log local0. “Client IP is: [IP::client_addr]”
if{[matchclass [IP::client_addr] equals $::fmw_nodes]}
log local0. “SNAT activated …”
else
log local0. “Redirecting …”
And please show us the log created this way.
It’s in /var/log/ltm
The redirection is working however the server ip shown in logs is the snat ip. My machine ip is different 137.72.226.151
Mar 3 12:07:45 tmm tmm[1089]: Rule fmw-test2 : Redirecting …
Mar 3 12:07:51 tmm tmm[1089]: Rule fmw-test2 : Client IP is: 192.168.253.250
Mar 3 12:07:51 tmm tmm[1089]: Rule fmw-test2 : Redirecting …
Mar 3 12:07:55 tmm tmm[1089]: Rule fmw-test2 : Client IP is: 192.168.253.250
Mar 3 12:07:55 tmm tmm[1089]: Rule fmw-test2 : Redirecting …
Mar 3 12:08:01 tmm tmm[1089]: Rule fmw-test2 : Client IP is: 192.168.253.250
Mar 3 12:08:01 tmm tmm[1089]: Rule fmw-test2 : Redirecting …
Mar 3 12:08:05 tmm tmm[1089]: Rule fmw-test2 : Client IP is: 192.168.253.250
Mar 3 12:08:05 tmm tmm[1089]: Rule fmw-test2 : Redirecting …
Please note that i want to snat the “fmw_nodes” and make sure that these nodes doesnt redirect to HTTPS. All other requests should redirect from http → https.
Q. When the fmw_nodes condition matches in the first part then it doesnt fall through the “else” part right?
yes you’re right about your question
In your iRule, use [IP::remote_addr] instead of [IP::client_addr]
Sorry i didnt get it. Where do you want me to use remote_addr? in the “if” condition?
yes replace [IP::client_addr] by [IP::remote_addr] everywhere
I have tried with remote_addr… Please find the below logs. Looks like the remote addr given is the ip address of the pool servers. I am trying from a machine which is having ip different than “fmw_nodes”… why is “if” condition i.e. snat taking place? My web browser is taking me to the https page.. is that something we can change in the iRule?
Mar 4 07:45:08 tmm tmm[1089]: Rule fmw-test3 : Client IP is: 192.168.253.110
Mar 4 07:45:08 tmm tmm[1089]: Rule fmw-test3 : SNAT activated …
Mar 4 07:45:11 tmm tmm[1089]: Rule fmw-test3 : Client IP is: 192.168.253.111
Mar 4 07:45:11 tmm tmm[1089]: Rule fmw-test3 : SNAT activated …
Mar 4 07:45:18 tmm tmm[1089]: Rule fmw-test3 : Client IP is: 192.168.253.110
Mar 4 07:45:18 tmm tmm[1089]: Rule fmw-test3 : SNAT activated …
Mar 4 07:45:21 tmm tmm[1089]: Rule fmw-test3 : Client IP is: 192.168.253.111
Mar 4 07:45:21 tmm tmm[1089]: Rule fmw-test3 : SNAT activated …
Mar 4 07:45:28 tmm tmm[1089]: Rule fmw-test3 : Client IP is: 192.168.253.110
Mar 4 07:45:28 tmm tmm[1089]: Rule fmw-test3 : SNAT activated …
Mar 4 07:45:31 tmm tmm[1089]: Rule fmw-test3 : Client IP is: 192.168.253.111
Mar 4 07:45:31 tmm tmm[1089]: Rule fmw-test3 : SNAT activated …
Mar 4 07:45:38 tmm tmm[1089]: Rule fmw-test3 : Client IP is: 192.168.253.110
Mar 4 07:45:38 tmm tmm[1089]: Rule fmw-test3 : SNAT activated
