Selected client SSL does not match security policies for VS after cipher update
I’m trying to update ciphers on one of my profiles. The one I want to use is:
!LOW:!SSLv2:!SSLv3:!MD5:!RC4+SHA:!EXPORT:!DHE:ECDHE+AES-GCM:ECDHE+AES:AES+SHA+RSA:@STRENGTH
This works fine on another VS, but an attemtp of installing it on this one results in this error:
0107157c:3: Selected client SSL profiles do not match security policies for Virtual Server /EXTERNAL/vs_server_443.
Now the OK and NOK vs are a bit different, but I can’t figure out which portion of the config can be responsible for this error. Let me summarize the differences:
vs_NOK_443
Protocol Profile (Client):  prot_tcp_client_name_WAN (based on tcp_wan_optimized)
Protocol Profile (Server):  prot_tcp_client_name_LAN (based on tcp-lan-optimized)
HTTP Profile:               http_xff
vs_OK_https
Protocol Profile (Client):  tcp
Protocol Profile (Server):  (use Client Profile)
HTTP Profile:               http_xff_redir-rewrite
Now i do not see any difference between http-xff and http-xff_redir_rewrite is that the latter uses a Server Agent Name
Both server have two client ssl profiles and the profile in question is marked as the default profile for SNI.
Is there multiple clientSSL profile assigned to vs_server_443?
If there are multiple clientSSL profiles on the same VS, all profiles must be changed simultaneously.
