Select Specific Monitor for Health Monitor "Availability Requirement"
From “Availability Requirement” option of a Pool we can select at least minimum number of Monitor as a Prerequisite for a Pool to be UP.
I have 3 monitor for example I want to specify 2 monitor at least to be UP. But I do not see any option to select a Specific Monitor ?
Any suggestions on how to do that ?
There is no way to do that - you either specify that all monitors are required, or a minimum number of monitors of the available monitors are up.
ltm pool http_pool {
    members {
        10.0.0.145:http {
            address 10.0.0.145
            session monitor-enabled
            state up
    monitor min 2 of { tcp gateway_icmp http }
or
    members {
        10.0.0.145:http {
            address 10.0.0.145
            state up
    monitor tcp and gateway_icmp and http
You cannot mix the min key option with the and option in the configuration.
