Select pool based on client certificate and URI
Hi.
I am new on Irules and I have this requirement:
It is a VS and it is needed this conditioning based on client certificate and URI in order to select the pool:
if client sends ssl certificate set HEADER1 and balance to pool1 else if clients connects and URI matches /static balance to pool2 else balance to pool3
HEADER1: add header X-SSL-Client-CN and set it as %[ssl_c_s_dn(cn)]
Thanks a lot for any answer.
Best regards
Check these links:
iRule: insert cert info into HTTP headers
SOL5171
The above links should be able to provide you with a template to work on an iRule that would be useful for you. If you still assistance, paste the iRule that you have created for further assistance.
