what are the security headers that sould be added in all websites? is there any irule to add all needed headers?
@THE_BLUE The following article is something I found with best practices for security headers and based on what I can tell you can create an iRule or use a virtual server setting accomodate them all. I don’t know of a standard iRule for each use case but I would imagine search DevCentral (this forum) for the respective header will provide you several articles where someone has solved this issue.
The following is an example of a search that can be performed on a topic in the URL provided above.
Hi @THE_BLUE ,
Please have a look in the following Articles :
In addetion to using Cookies and http only features.
