SecurID + (AD or LDAP) two-factor auth?
I would like to set up a master group that requires successful password and SecurID authentication. I don’t see that this is possible but hopefully I’m missing something. Thoughts?
Under Users → Global Settings you can enable an additional domain password and bind it to a specific landing URI or VHOST. Then you create a Master Group to use RSA and also bind it that URI or VHOST and that should give you exactly what you need!
Cheers,
Mal
Ah sweet, I’m checking that out. Thanks Mal.
