Secondary IP limit on AWS
Hi, We have deployed BIG-IP LTM on AWS and are using secondary IPs to assign to our Virtual Servers. But as the Amazon limitations indicate, we are limited to 15 secondary IPs per interface, this limits the number of VIPs we can deploy. Adding another interface would create inconsistent routing. Can you help me with a solution to overcome this limitation?
The Amazon IP allocations per interface fit into CIDR ranges (/28 or /29)
- each interface needs to be given a self-IP/mask from an appropriate CIDR range and virtual IPs assigned appropriately
