Hello
Am updating this, having narrowed down the issue slightly
Am running VE BIG-IP 11.2.1 Build 797.0 Final, and have successfully imported configurations from v10.x to the new platform.
I have noticed is that when the node list has imported from version 10.x to v11.x what was the orginal NAME field for the node has been changed the DESCRIPTION field; and the IP address for the node has been allocated as the new NAME for the node.
This wouldn’t be so bad but it seems as if the search/filter function in the node list view DOES NOT search via the desctiption.. Which means that I currently cannot narrow down the node list by using searching for a friendly name.
any help greatfully received!
Kindly thanks ![]()
Daniel
