Scripted Monitor + REGEX
I trying to do a Scripted monitor but there is no much enough documentation available saying about use regular expressions in that configuration.
send “GET /myurl HTTP/1.1\r\n” send “Host: www.myhost.com.br\r\n”
send “User-Agent: Mozilla/4.0+compatible;+MSIE+7.0;+Windows+NT+5.1;+Trident/4.0;+.NET+CLR+1.1.4322;+.NET+CLR+2.0.50727;+.NET+CLR+3.0.4506.2152;+.NET+CLR+3.5.30729;+.NET4.0C)” send “Connection: Close\r\n”
send “\r\n\”
send “\r\n\”
expect “PUT HERE THE REGEX”
Are you talking about with an external monitor? If so, this post might help, along with SOL5917.
If you’re talking about a normal HTTP monitor, then you can use regex in the receive string based on SOL5917.
