Screenshot of a working APM Machine Cert Checker
Does anyone have a working config for the APM “Machine Cert Checker(Auth)”, if so a screenshot would be useful? The F5 doco is vague at best.
close
do you need help in this topic?
  • Certificate Store Name: MY
  • CA Profile: you have to set your CA profile (you can create it before)
  • Certificate Store Location: LocalMachine
  • Save Certificate in a session variable: Enabled
  • Allow User Account Control right elevation prompts: yes
  • Match Issuer (example): .CN=yourCNname.
If you need more details don’t hesitate.
regards,
